TwinTurbo.NET: Nissan 300ZX forum - Re: Engine Oil Pressure Gauge says 0
Subject Re: Engine Oil Pressure Gauge says 0
Posted by deviousracing on May 05, 2011 at 6:45 PM
  This message has been viewed 133 times.
In Reply To Engine Oil Pressure Gauge says 0 posted by deviousracing on May 04, 2011 at 12:01 AM
Message :and my speedometer and coolant temperature might not be working. this weekend I replaced my power steering pump and when i was taking it for its test drive I noticed that 3 of the gauges were not working.
:first thing i did was check the oil pressure sending unit, it read 36 ohms at idle. so I dont think its that. I checked every fuse, they all look ok, but I didn't meter them out
:I have a check engine light on, the codes are 34 and 51 Detonation sensor and Injector circuit, im cleaning my injector connectors this weekend, they are dirty
:any ideas?
:is 36 ohms a good reading for the oil switch?
I figured it out, i was a loose connector in the alternator to engine harness, i knocked out near the power steering pump
